angusuk
Posts: 63 Joined: Thursday 10th Apr 2008, 12:07
Post
by angusuk » Sunday 18th May 2008, 2:27
seems to run very hot after using for about 1 hour,is this normal,casing gets hot,does have a large added heatsink on the back.
thanx angus
Posts: 1041 Joined: Sunday 4th Jun 2006, 12:52
Post
by Rick » Monday 19th May 2008, 9:26
If the output is more then 5 watts on AM/FM then it will get not, especially down the left-hand side, sooner or later it will blow the final.
angusuk
Post
by angusuk » Monday 19th May 2008, 13:05
rick i forgot to mention it does have a fm varable power nob on the back,
and looking inside its had the pot removed and the 2 wires added to the nob.
so should i remove the nob and fit a new pot and set to 5watts.to be on the safe side.
