Uniden PC78LTW cooked
Well yes I did, I hooked my PC78LTW up to a trickle charger thinking I could power it up that way. Your right I fried it. Any idea what diode I need to look at
The polarity diode is almost certainly toast. You can find it by following the radios power wires down to the board. It will be a black diode, more than likely, it may be cracked down the middle. If the diode is shorted, then the rest of your radio is probably ok.
Trickle chargers are very unpure and unfiltered DC, they have an AC component to them which is why it fried your radio.
- Heavy User
Ok it was D23. I replaced it and it's working great. 2@ $0.99 at radio shack. Thanks for the help.
Another thing I'm trying to learn is positive side and neg. side. I have a Cobra 25 that I tinker with trying to learn. I lifted the foil trying to add a swing kit. How do I identify where to hook up a jumper wire.
- Heavy User
my d was for a cobra 29, my bad...you mean you want to fix the trace??rac29fan wrote:Ok it was D23. I replaced it and it's working great. 2@ $0.99 at radio shack. Thanks for the help.
- Heavy User
