Super Panther SSB
Posted: Wednesday 30th Jul 2008, 11:58
by lucky phil
Does SSB use audio chip as i have no modulation on SSB, audio RX or TX..?
Posted: Thursday 31st Jul 2008, 3:34
O.K.. First you need to give us better info.. on the unit
before we can help..Like first of all What is the P.C.B. Number????
Board No
Posted: Thursday 31st Jul 2008, 15:43
by lucky phil
It is the common single board. 02A SSB... TP-DN60-HB is all i could see on it.
Re: Pearce-Simpson Super Panther.
Posted: Thursday 31st Jul 2008, 20:10
The Pearce-Simpson Super Panther was never a popular radio, therefore Sch diagrams are hard to come by, this is most likely why you are not getting a answer.
They are two version of the Super Panther Mk1 and MK2 I think its only the MK2 which has the label MK2.
If the PCB is the PTBM048ACOX or the PTBM058COX then check the mode switch as it switches on the RX/TX switching transistors and this is the only common control line used in SSB.
The transistors are Q40 and Q41.
Q40 (TX SW) emitter should be about 8 to 8.5 volts when in the on SSB mode and the collector should be about 8 to 8.5 volts in TX and zero in RX.
Q41 (RX SW) the collector should be about 8 to 8.5 volts when in the on SSB mode and the emitter should be about 8 to 8.5 volts in RX and zero in TX.
next prob
Posted: Monday 4th Aug 2008, 22:25
by lucky phil
I beleve it is the Mk1...this is a very common radio in Australia....Ok.. Replacing the audio chip got the audio working.. but RX on SSB is very low also on SSB TX.. but all good on AM....??????????????
