I just got an old HR2510 and was checking it over to make sure it is ok.When checking the bias on the driver and final I notice that it is almost impossible to set the bias to 50ma on the driver, seems to be erratic, I cleaned up the VR but its still the same, the final is bang on just the driver seems to be so touchy, any ideas?
Tnx Bob
HR2510 bias adjustment
captian_radio
captian_radio
captian_radio
hamguy2
- Light User
htx 100 and 2510 and 2600
hi so you know if you stick a pair of mrf477s in them theyll do 100 watts ssb easy same as the htx 100 same chip. but its not all mode you can put lsb back in the htx 100 also am etc but a fair bit of work needed ,thanks hamguy2 nsw australia
captian_radio
