President Lincoln problem no RX
Posted: Friday 24th Oct 2008, 10:35
Hello there,
I have a Rx problem on my(President Lincoln) because I had an accident.
I was working to replace the MRF477 to a MRF455 and I had the PB101 AB
away and when i was finished with replacement I was ready to put the PB101 back but I drop it and it shortcut between mounts for the PB and D101-D102 the radio was off but it was still power on the mounts a lot of sparks .
First thing I notice was that I have no RX the squelch only works on SSB and CW nothing on AM and FM,No buzz when i connect the antenna,
No readings on the S-meter,The blip sound is gone when I push buttons
now is only some noice.
Broken components that I found was D101-D102 D126 Q101 (Q102 was ok)
I tried and replace the componets but still no Rx.
I did some measurement on the IC 101 on My second Lincoln thats working,Mod AM 28.000Mhz mobile antenna,
(IC 101)
Pin1 1,25V
Pin2 0,66V
Pin3 0,66V
Pin4 9,33V
Pin5 0,00V
Pin6 1,95V
Pin7 0,01V
Pin8 0,01V
Pin9 3,20V
Pin10 1,47V
Pin11 0,00V
Pin12 0,66V
Pin13 0,66V
Pin14 0,86V
Measurement on the IC 101 on my broken Lincoln thats not working,Mod AM 28.000Mhz mobile antenna,
(IC 101)
Pin1 1,44V
Pin2 0,72V
Pin3 0,00V
Pin4 10,24V
Pin5 0,00V
Pin6 1,97V
Pin7 0,03V
Pin8 0,03V
Pin9 8,38V
Pin10 1,67V
Pin11 0,00V
Pin12 7,06V
Pin13 5,62V
Pin14 7,92V
Does some one have a clue what could be the problem I want to get it back to working condition again
I am very grateful for any idea.
Best regards
Per Andersson
Sweden
p,s Sorry for my bad english
(IC 101)
Pin1 1,25V
Pin2 0,66V
Pin3 0,66V
Pin4 9,33V
Pin5 0,00V
Pin6 1,95V
Pin7 0,01V
Pin8 0,01V
Pin9 3,20V
Pin10 1,47V
Pin11 0,00V
Pin12 0,66V
Pin13 0,66V
Pin14 0,86V
(IC 101)
Pin1 1,44V
Pin2 0,72V
Pin3 0,00V
Pin4 10,24V
Pin5 0,00V
Pin6 1,97V
Pin7 0,03V
Pin8 0,03V
Pin9 8,38V
Pin10 1,67V
Pin11 0,00V
Pin12 7,06V
Pin13 5,62V
Pin14 7,92V
Best regards
Per Andersson
Sweden
