Roger beep for Galaxy 919, and 929.
Posted: Saturday 25th Oct 2008, 18:31
by marveylus22
add a jumper wire or SPST switch to the empty 2 holes on J10 (8v and RB).
Its in the front of the radio, 1 inch behind the meter, just like all the Galaxy's.
There aren't any controls on the radio for it, but I guess they just threw it in there for some reason.
If you want a simple switch on the front of the radio using the NB/ANL CB PA switch follow these directions.
Find J6, 3 wires. Green (8v), Yellow (ANL), Orange (NB).
Cut the Orange Wire (NB) at the plug.
Solder it into the RB hole for J10.
If you want more more static, leave as is.
If you want less static, cut the Yellow Wire (ANL) at the plug and tape off the wire.
Using the NB/ANL setting will turn ON the Roger Beep.
Using the CB setting will turn it OFF.
