Galaxy DX 959 swing kit?
Posted: Monday 27th Oct 2008, 3:41
by mongoose
I have a DX 959 and was wondering if it would be a good Idea to put in a swing kit in it and if so what do I need. I have done the channel mod and it works great, the freq counter follows right along. Thanks in advance.
Mongoose
Posted: Monday 27th Oct 2008, 6:07
by timrim
Because the DX959 has a carrier adjustment on the main board, a swing kit could be installed but would not be necessary as long as the modulation limiter is removed. All you would need to do with the limiter removed, would be to set the dead key low. There are various mods that you can do to the radio, but the above is the easiest way to get LOUD punchy audio with plenty of swing, is stated above.
