MRF 477 replacement with IRF 520
Posted: Monday 27th Oct 2008, 20:30
by Emelso
I got an old President Jackson (silver faceplate) with MRF 477 final, which has been banged :(
Is there any chance to replace/rebuild it with IRF 520 or similar FET? :roll:
Thanks!
Posted: Monday 27th Oct 2008, 21:33
You can probably replace it with a MRF455 instead,it will require different mounting, and some capacitor changes (as per the HR2510 / Lincoln mod), but I expect it would work, and I doubt the final would ever fail again.
Posted: Tuesday 28th Oct 2008, 0:31
by Emelso
Hi Defpom, tnx for help! I know this mod, but MRF 455 is hard to get and expensive (by us). I saw some good mods for 2SC1969/2312, now I try to redesign it for the 477.
Posted: Tuesday 28th Oct 2008, 9:52
by Warbird
Isn't there a mod around somewhere for the HR2510/HTX100 that replaces the 477 to 455 mod with a 1446? The IRF520s are not a pin for pin replacement for the 477 and you wind up with them "cross-legged".
Posted: Tuesday 28th Oct 2008, 10:24
by timrim
You can directly replace the 455 with the 1446, so do you just need the mod? I may have a Lincoln here somewhere that has a 455 in it.
Posted: Wednesday 29th Oct 2008, 4:40
by Emelso
I know the mod with MRF 455, as I wrote it before. I just need a cheap solution for the final.
hr2510/lincoln
Posted: Thursday 30th Oct 2008, 6:39
by warhorse
Hi, this pre rogerbird mod works well'' uses sd 1446. this download site is currently ok.3 pics show the mod (ziped)virus free.
http://rapidshare.com/files/12584867...Mod__.zip.html
re2510/lincoln mod
Posted: Thursday 30th Oct 2008, 6:54
by warhorse
Re: re2510/lincoln mod
Posted: Tuesday 15th Nov 2011, 18:35
by KC7NOA
Long gone .... still somewhere??
