Galaxy 33HML problem
zinger827
Post by zinger827 »
I have a 33hml that wont change power settings from lo-med-high? Stays at same wattage no matter where its switched? I posted a pic of solder side showing 2 wires do not know if factory or maybe part of problem? Thanks.
smokinjoe
Post by smokinjoe »
If this radio has the frequency counter plug in on the back of the radio the two wires go to it and have nothing to do with the power these were installed from factory.
zinger827
Post by zinger827 »
No freq. counter plug on back. Very common board I never seen wires on them before? Probably some kind of mod?
timrim
Post by timrim »
Wires seem to be going to PA jack, I believe its normal for that board.
As for the power issue, there should be at least 2, possibly 3 adjustments for power settings, have you tried to adjust them? Perhaps someone set them the same, so that they did not fry their amp?
zinger827
Post by zinger827 »
I did try to adjust the VRs with no luck. Only the high power VR did anything with the L13 the Lo/Med ones did nothing? Im thinking maybe bad h/m/l switch? Thanks.
Re: Galaxy 33HML TX power problem.
If it is stuck on hi power, try changing TR51.
zinger827
Post by zinger827 »
Checked TR51 working right?
What is the voltage at the Base and Collector of TR51 with the power switch in Low, Mid and Hi?
What is the voltage at the Base TR49 with the power switch in Low, Mid and Hi?
zinger827
Post by zinger827 »
tr51 12.8/6.8/13.4 tr49 7.3/13/6.8 ecb on lo and high in med .11/13/.42?
It looks like you did not understand my last question.
If you need help you need answer only the question, you are asked.
What VR have you tried to adjust?
zinger827
Post by zinger827 »
vr 13-16-23 only vr 13 did anything.
zinger827
Post by zinger827 »
Found cold solder joimts at the med. power VR. Radio seems to be working fine now. Thanks for help.
With the voltages, you gave me it was obvious what the fault was.
That why I ask you which VR have you tried to adjust the clue was in the question.
I could have just told you to check for cold solder joint or open circuit VR, but would not help you fault finding in the future.
……..Check voltages tell a thousand truths………
zinger827
Post by zinger827 »
I appreciate the help as im sure many here do. Next problem I will definatly be more specific with the problem. Thank You.
