I just installed an irf520 in my cobra 29/NW/ST. It worked at first and only had a talk range comparable to my TRC-52. So I opened it back up and started expirimenting with some capacitance values. I was futzing around with capacitor values for C62 [I installed a 470pf cap here when I changed the final; I also removed the capacitor that was across it on the solder side]. I was going for a lower value so I paralleled two 220pf caps in place of the 470pf cap. I noticed my transmit audio increased, much louder with less clipping and distortion. I left the radio on, went and got something to drink, came back and noticed that when I keyed up the mic, the rf power meter on the radio barely even moved at all.
So I changed the 2 220pf caps back out with the 470pf cap. Nothing. The TX transmit lights up, and I could hear audio when I was transmitting to my nearby handheld unit. But the TX meter moves to around 1. What could have happened? Maybe I burnt up the driver?
I didn't use the en1230 part, instead I used a diode + resistor pair configured this way: GROUND <------>|------^^^^-----------> MOSFET GATE. The diode was an everyday 1n4148? and I used a 470ohm resistor with ferrite bead on the end.
I hope someone can help as this is the only 29 I got!
cobra 29 irf520 mod problem
Cobra 29/NW/ST
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
Okay, it was the driver. I had a 2sc2028 (I think... some of the print was worn off) laying around, so I put in and it seems to work now. Is this a suitable driver replacement? The original driver was a 2sc1957.
Also, anybody who has done this mod, what kind of distance have you gotten? I have a 54" center-loaded mobile antenna with open coil. I'm also using it in my car, so I guess the supply voltage is around 14vdc.
Cobra 29/NW/ST
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
Yes, it will work fine. That is what some of the older versions used.
What kind of power output did you have when you first finished the mod?
Re: cobra 29 irf520 mod problem
Thanks. Mine is one of the older ones that used the 1957, but the 2028 seems to work even better!timrim wrote:Yes, it will work fine. That is what some of the older versions used.
Cobra 29/NW/ST
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
When I first finished, before frying my driver , I measured around 2 watts dead key and 18 watts swing, not much at all. But after replacing the driver, fiddling with capacitance, resistances, and retuning her, I am seeing about 5 watts dead key and 39 watts swing, not bad for .90 cents worth of parts!dizgolfer wrote:What kind of power output did you have when you first finished the mod?
Cobra 29/NW/ST
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
That sounds really good. I did this mod once using directions somewhere on this site and I got about the same thing maybe a little less.
