Uniden PRO 510xl Problem
Posted: Friday 19th Dec 2008, 23:14
Radio Make and Model: Uniden PRO 510xl
PCB Number: PA-402AA 1/3 (i think)
PLL Number: SM5124A
Test gear available: VOM
Symptoms: audio IC gets hot
The radio works fine. I just bought it on ebay. I noticed that while the unit is powered on, the audio IC begins getting warmer and warmer until it is hot to the touch. This was tested without transmitting and volume/on - off pot was set at low volume. Also I am not using external speakers.
Any help would be most appreciated.
PLL Number: SM5124A
