cpi 300 power plug socket pins
aussie
Post by aussie »
Radio Make and Model: cpi 300
Test gear available:
Symptoms:
What is working:
What has been tried:
Did it suddenly happen ?:
hi all i have a cpi 300 cb thats missing its power lead, on the back of the radio it has a 6 pin socket for the power lead to plug into. what i need to know is what pin is positive and which one is negitive so i can make up a new power lead so i can fire it up again. a picture or sketch of the back of the radio right side up with the pins marked would be most helpful. thanks for any help.
jenny cber downunder
Warf135
Post by Warf135 »
Open up the radio, and you may see the colour of the wires going to the socket.
Or you can find the pins you need easily with a continuity tester:
1, turn power switch of radio on
2, connect one test lead to switch contact
3, probe the pins on the power socket with the other test lead
4, when you get a dead short showing on tester, thats the positive (red wire) connection
5, then put one test lead on the metal case of the radio, and do the same.
6, when you get a dead short, that'll be the negative (black wire) connection.
Hope this helps.
aussie
Post by aussie »
thanks for the reply warf135 the old girls working again., its only working on 23 channels so if any one knows how to get 40 or the 1 to 99 channels would be a great help cheers aussie :wink:
