Cobra 148GTL, only 2 channels functioning
Posted: Wednesday 18th Feb 2009, 7:19
by frogman296
Radio Make and Model: COBRA 148GTL
PCB Number: PC416AA
PLL Number: MB8719
Test gear available: bird meter, BK2040 sig gen, multimeter, freq counter
Symptoms: radio has rx and tx on channel 1 and 20
What is working: only channel 1 and 20 work on the receive and transmit. radio is showing the watts it should.
What has been tried: the radio on the external freq counter is showing that it is receiving on frequency. went through 1-40am and found that only 2 channels work
Did it suddenly happen ?: yes it happened all of a sudden
Anything else that may be of help?: this radio was just professionally aligned, got a clean bill of health.
any help is much appreciated, i am sure somebody here must have had this problem before
Re: Cobra 148GTL, only 2 channels functioning
Posted: Saturday 21st Feb 2009, 9:16
You need to check the binary code going into the PLL, pins 16 through to pin 10, it is likely that a solder blob is shorting a couple of pins out, causing the PLL to jump to the wrong frequency, or there is some other fault causing an incorrect binary code.
So what you need to do is tell me what the binary code is for every channel, measure the voltage, anything below 1.5V is "0", above that is "1", you should see a distinct voltage difference between a "low" and a "high".
Example:
Ch 1: 1 1 1 1 0 0 1
Ch 2: 0 0 0 0 1 0 1
Posted: Tuesday 3rd Mar 2009, 4:06
by frogman296
went through the radio.... reversed the channel mod, and clarifier is now locked.
replaced the crystal with the stock crystal....changes mike plug to 4 pin
powered the radio up... worked perfect... 5 minutes later..... no power output in any mode... no mike audio through talkback, and no "tx light"
weird?
Posted: Tuesday 3rd Mar 2009, 10:41
by frogman296
The Defpom wrote:You need to check the binary code going into the PLL, pins 16 through to pin 10, it is likely that a solder blob is shorting a couple of pins out, causing the PLL to jump to the wrong frequency, or there is some other fault causing an incorrect binary code.
Example:
Ch 1: 1 1 1 1 0 0 1
Ch 2: 0 0 0 0 1 0 1
okay... i got a question... when i touch the lead to each pll pin... should the voltage be floating??? if so do i hold it until it settles??
Posted: Tuesday 3rd Mar 2009, 14:40
You may want to re-check the clarifier mod, in case it is shorting the TX and RX lines together, it sounds like the MB3756 may have failed.
Make sure you connect your negative test lead to one of the metal cans on the PCB, and not the chassis, as the chassis is not a true 0V.
Posted: Tuesday 3rd Mar 2009, 15:55
by frogman296
The Defpom wrote:You may want to re-check the clarifier mod, in case it is shorting the TX and RX lines together, it sounds like the MB3756 may have failed.
i will recheck the clarifier mod to be sure.... and will get the voltages...
thanks in advance scott
Posted: Tuesday 3rd Mar 2009, 16:14
Also make sure that any diodes or resistors on the clarifier circuit have been restored and are not bridged or anything, often they are, which could put too much strain the the MB3756 if the clarifier is turned fully in one direction.
Posted: Tuesday 3rd Mar 2009, 19:32
by frogman296
1. 1 1 0 1 1 1 1
2. 1 1 1 0 0 0 0
3. 1 1 1 0 0 0 1
4. 1 1 1 0 0 1 1
5. 1 1 1 0 1 0 0
6. 1 1 1 0 1 0 1
7. 1 1 1 0 1 1 0
8. 1 1 1 1 0 0 0
9. 1 1 1 1 0 0 1
10. 1 1 1 1 0 1 0
11. 1 1 1 1 0 1 1
12. 1 1 1 1 1 0 1
13. 1 1 1 1 1 1 0
14. 1 1 1 1 1 1 1
15. 1 1 0 0 0 0 0
16. 1 1 0 0 0 1 0
17. 1 1 0 0 0 1 1
18. 1 1 0 0 1 0 0
19. 1 1 0 0 1 0 1
20. 1 1 0 0 1 1 1
21. 1 1 0 1 0 0 0
22. 1 1 0 1 0 0 1
23. 1 1 0 1 1 0 0
24. 1 1 0 1 0 1 0
25. 1 1 0 1 0 1 1
26. 1 1 0 1 1 0 1
27. 1 1 0 1 1 1 0
28. 1 1 0 1 1 1 1
29. 1 1 1 0 0 0 0
30. 1 1 1 0 0 0 1
31. 1 1 1 0 0 1 0
32. 1 1 1 0 0 1 1
33. 1 1 1 0 1 0 0
34. 1 1 1 0 1 0 1
35. 1 1 1 0 1 1 0
36. 1 1 1 0 1 1 1
37. 1 1 1 1 0 0 0
38. 1 1 1 1 0 0 1
39. 1 1 1 1 0 1 0
40. 1 1 1 1 0 1 1
Posted: Tuesday 3rd Mar 2009, 20:12
There is an error with the N codes, the ch1 code should be 1001111, not 1101111, check for problems with the connections for pin 11, try checking the diode matrix that is used for the CH9 funtion, or lifting the wire from the ch selector for that pin.
Posted: Tuesday 3rd Mar 2009, 20:17
by frogman296
the radio does not have the instant channel 9 function.
so i should check pin 11 of the pll and its path through the radio??
Posted: Tuesday 3rd Mar 2009, 21:00
Of course, no CH9.. but yes, check the path and source of the voltage feeding pin 11, if you disconnect it from the ch selector and test the ch selector side for voltage it should say whether the selector is at fault, or if there is a short circuit somewhere (it should be feeding 0V), the PLL pin will measure high when disconnected, as the PLL uses internal pull up resistors on its pins, if you connect pin 11 through a 2K resistor to 0V if should drag it low, if not, the PLL could have an internal fault.
Posted: Wednesday 4th Mar 2009, 3:20
by frogman296
The Defpom wrote:Of course, no CH9.. but yes, check the path and source of the voltage feeding pin 11, if you disconnect it from the ch selector and test the ch selector side for voltage it should say whether the selector is at fault, or if there is a short circuit somewhere (it should be feeding 0V), the PLL pin will measure high when disconnected, as the PLL uses internal pull up resistors on its pins, if you connect pin 11 through a 2K resistor to 0V if should drag it low, if not, the PLL could have an internal fault.
selector checks out
adding the resistor from pin 11 to 0v doesn't drag it low...
should i replace the pll??
Posted: Wednesday 4th Mar 2009, 8:56
by frogman296
replaced pll
now i can align the RX on freq... but i transmit off freq.... it seems as though there is not enough adjustment to the tx freq VR 5
on a side note... when i unlocked the clarifier.... the radio will align...
looks like the pll crapped out... thanks a million Scott
Posted: Wednesday 4th Mar 2009, 14:20
The TX alignment issue is probably due to the original clarifier mod, check for correct component values for the resistors that are connected by VR5.
On the TX side R187 should be 2.7K, R186 should be 100 Ohm, there should also be diodes in D75 and D52.
On the RX side R175 should be 3.3K, R174 should be 12K, R44 should be 8.2K.
Posted: Thursday 5th Mar 2009, 2:53
by frogman296
The Defpom wrote:The TX alignment issue is probably due to the original clarifier mod, check for correct component values for the resistors that are connected by VR5.
i don't even see a r175 in this radio... i know where the location is... but i haven't been able to actually find the darn thing
will check the others
http://www.radiomods.co.nz/cobra148gtlmods.html
the above link is the clarifier unlock that i used... even though i have no r175 to change out... the mod works perfect
Posted: Thursday 5th Mar 2009, 12:11
by frogman296
checked the others... added correct values.... still no luck... i went back to the unlocked clarifier...
radio works A+
