Radio Make and Model:RCI-2985DX
PCB Number: EPT695014B
Test gear available: basic
Symptoms: Picked up a radio tonight and it works great except for one issue. If you keep the RF power turned down around 2W or less dead key you can hear fine. If you increase it more the volume from the speaker decreases but you can turn the volume know up to compensate. If you dont compensate, then if you continue to increase the RF power you will lose all sound. This also happens if you increase the RF power pot inside the radio (A/F Power) The radio has had the finals changed to a MRF477's and the PS has been swaped out for one out of a 2527 so any help would be great. It works fine just is annoying.
73's!
Truck
What is working: Everything
What has been tried: Not sure what to try
Did it suddenly happen ?: customer stated it was like that when it cam eback from the PS swap but unsure
