PCB Number: PCB-416AA
PLL Number: MB8719
Test gear available: Astatic 600 3 way power meters, MFJ 1.5KW Dummy Load. Voltage Test volt meters.
Symptoms: Meter Malfunction. Non Responsive
What is working: Everything.
What has been tried: Removed meter and tried adjusting the Tiny meter set screws.
Did it suddenly happen ?: Was bought yesterday with this Malfunction.
The Problem is the meter does not function. It lights up but no movement at all even when she is keyed up. I noticed the meter was stuck about 3/4 of the way up and was able to bring her back down. Still nothing. Tried moving the fine tiny adjustment on the actual meter but still No response on transmit or receive. Other than that the radio works great. Any Ideas on what can be causing this Malfunction? Thanks Guys
