Radio Make and Model: Ranger RCI 2950 non-DX
PCB Number: EPT 295013B
Test gear available: Motorola R2210B service monitor, power meters, oscilloscope
Symptoms: the radio deadkeys about 5 watts, and swings to about 6. When the deadkey is held for about 10 seconds or so, the power decreases slowly.
The radio modulates good, and the waveform on the scope is clean. Occasionally, the power output dissappears altogether. The meter shows a reverse modulation effect as well. this radio has just been given to me, and this is the first one I have ever worked on, so all help will be appreciated
What is working: Nothing yet
What has been tried: Preliminary testing
Did it suddenly happen ?: since it was a preowned radio, I do not know if this problem was ongoing or not
Anything else that may be of help?: As of right now.... nothing
RCI 2950 non-DX, low output power, etc.
theradionerdz
- First Name: James
Classic CB
- First Name: Andy
Re: RCI 2950 non-DX, low output power, etc.
Hi: I would be checking the output transistors & driver as a starter. Had 1 of these a while back where the output transistors had been changed for underrated types & had no thermal compound on them, exhibited very similar symptoms. Also make sure you check for dry solder joints around the RF stages with a strong illuminated Magnifier.
Andy @ Classic CB
Andy @ Classic CB
Does the power comes back when the radio is cold? I would check the output transistors & driver at first step too.
