I have setup three different "Styles" that you can choose from, you can select the style you prefer in your Profile using the link at the top of the page, the current styles are: subSilver, DefpomStyle and Charcoal2.
I will be making small alterations to these styles to change the look of things I want to change, so if you see anything that does not look right, or you think can be made better in some way please let me know by posting a message in this forum catagory.
I can set everyone who uses the forum to use the same style, so if you login and find that it has suddenly changed it is probably due to me doing this, you can still change the style back to what you had if you prefered it, using the detail shown above.
Click HERE to view and edit your profile.
How to change the look of the forum
