COBRA 148 PC 412 ISSUE
Posted: Tuesday 23rd Jun 2009, 11:21
Radio Make and Model: 1978 -1997 COBRA 148 GTL
PCB Number: PC 412
PLL Number: MB8719
Test gear available: VM METER HP O SCOPE SIG GEN
Symptoms: BLOWN D44
What is working: THE RADIO IS WORKING
What has been tried: REPLACE THE DIODE
Did it suddenly happen ?: After overvolt or shorted transistor.
Anything else that may be of help?: It is a common problem i see all the time when restoring these radio`s. it is supposed to be a bad transistor that makes the diode blow. if you put a new diode in it blows the fuse. the radio works fine with d44 out of it. can you help out rick or anyone. thanks very much in advance.
PCB Number: PC 412
PLL Number: MB8719
Symptoms: BLOWN D44
