PCB Number: EPT695014B
PLL Number: sorry, haven't figured out yet
Test gear available: Counter, Scope, Digital V/A/Ohm, ToneGen
Symptoms: Blank Display
What is working: Rattle in Buzzer
prior to hanging my iron into those SMD, just one question: is that AM8005 on the CPU-Board able, to produce 3,2V if "blown"?
Story:
I got an 2950DX with a fault, never seen. CPU seems to be OK, the registers also, it reacts on several buttons (display lights comming, sometimes dimming), "rattle" becomes different or stucks while pressing a button etc. It seems, it will not start-up/reset. The regulator becomes HOT after just a few seconds and I measured 3,2V - so a bit low for the CPU. But since now I know of those regulators just three states: working, short-out or blown with no contacts anyway - but none had any lower output (exept total zero). So, prior of soldering (I hate SMD...) maybe for nothing, this above question
Maybe its just another short somewhere on the board I have to search... Any known issues on that model with that CPU-Board? By the way: I can't find THAT specific CPU-PCB in any documentation on Ranger. It has one more connector where a 3-wire-hotmelt-pack is comming out. Don't know what it is or does. Also it has a C619 wich I can't find on the shematic. Maybe export-version?
Thanks for your thoughts!
Regards,
Joe
