Radio Make and Model: Midland 48 Plus
Test gear available: Frequency Counter, 20Mhz Scope, Multimeter, SWR/Power meter.
Symptoms: No RX/TX
What is working: The display (lcd) will change over from rx/tx but the lights wont light up for power output. squelch audible but not right....
(but sounds like missing crystal? had a murphy homebase once and one of the legs was broken on the 10.24megs crystal)
What has been tried: visual inspection, nothing "blown"? tried changing 2SC1969 for another, but cant gaurentee that the replacement hadn't faulted already either.
Did it suddenly happen ?: Yes, it was working fine, i just been tidying it up after some screw driver expert had put in a relay to change it from 80/40 channel fm to 400 channel am. i may of shorted something or upset something or, its likely it could of given up on me?
