SUPERSTAR 360FM EPROM
mm3stb
First Name: Richard
Post by mm3stb »
Radio Make and Model: Superstar 360FM
PCB Number: PB010AB
PLL Number: MC145106
Test gear available: Dummy load, frequency counter, digital VOM, analogue VOM
Symptoms: Ch 26 - 40UK missing
What is working: High, Mid, Low band when eprom is turned off
What has been tried: checked and double checked all connections, replaced clear ribbon from ch selector to eprom
Did it suddenly happen ?: N/A
Anything else that may be of help?: as mentioned before it works fine on all bands when eprom is switched off
I recently removed the eprom that was fitted to this radio along with sill speaker jack mod. I decided to go for the spectrum communications SC106 http://www.spectrumcomms.co.uk/cbkits.htm#SC106 in kit form. After assembling the kit i proceeded to fit it to the radio. i decided not to fit the trim pot to the clarifier straight away and see if the eprom worked. At the moment the trim pot is still not fitted. It works fine ch1 - 25uk but ch26 - 40uk transmits on 27.851, it does not change.
Can anyone think of anything before i send the eprom back.
Re: SUPERSTAR 360FM EPROM
Post by zodiac »
What was the reason for removing the other Eprom, had it gone faulty.
What I'm getting at is, if one had a fault, or should I say if the radio had a fault before you removed the first Eprom then you need to find that fault first.
You should have checked the radio worked on all channels on all three bands before fitting the new Eprom.
The radio should cover the UK band as well as the other bands without the need to extend the VCO so you can rule that out, unless it's been adjusted too far.
mm3stb
First Name: Richard
Post by mm3stb »
The old eprom was removed because it was going haywire. Transmitting away up on the 10M band
The old eprom was removed a couple of months ago and the radio was working on all channels and on all bands and still does when the eprom is switched off (see 1st post). I checked it with a frequency counter after removing the old eprom and soldering jumpers where the track had been cut. also checked again before fitting eprom and after, providing the switch is in the USA position.
Thanks
Richard
Post by zodiac »
The Eprom is not switched on and off it's on all the time, it just changes from one program (set of codes) to another when you flick the switch.
At least you know the wires going to and from the channel switch are wired correct as it works on all three FCC bands, so the fault must be with the Eprom programming for the UK band or the switch wires for the UK band.
Give Spectrum a ring and see what he says.
mm3stb
First Name: Richard
Post by mm3stb »
Just got the EPROM back from spectrum comunications ans he said it checks out fine. I'm at my wits end now, can't work out where i'm going wrong. I've lost track of how many time i have check my connections.
Post by The Defpom »
It could be a badly etched PCB, get a fine knife blade and run it down between every single track on the EPROM PCB, the slightest residue of copper could cause an incorrect input to be seen by the EPROM, you may not even be able to see that the copper is there.
I assume that you have tried adjusting the VCO in case it is running out of lock above CH26UK ?
Also when you assembled the PCB, you did make sure that the resistor array had pin one (marked with a dot usually) at the same end as the voltage regulator ? so the resistor arrays pin 2 should line up with pin 1 of the EPROM.
Double check as well that you installed all four jumpers correctly on the PCB (one link on the top, three bridges underneath).
Post by zodiac »
Scott,
I don't think it's the input lines shorted as it uses the same input codes for all it's bands they don't change.
Richard,
I would agree with the VCO L18 needing a slight adjustment.
I mention the possible bad etching issue as I have come across it myself on one of my own EPROM PCBs, where a program line worked fine until a different band was selected, as the resistive effect of a partial bridge by copper residue from the band selection input dragged a program line voltage off when the line next to it was also at the same level as the band program line. (combined effect of the two lines each side of the problem one), it is very unlikely, but is possible.
I would go with the VCO adjustment first, to rule the easy thing out first.
mm3stb
First Name: Richard
Post by mm3stb »
The Defpom wrote: Also when you assembled the PCB, you did make sure that the resistor array had pin one (marked with a dot usually) at the same end as the voltage regulator ? so the resistor arrays pin 2 should line up with pin 1 of the EPROM.
Going by the diagram i thought that pin 1 of the resistor array had to go to pin 1 of the eprom so thats how i had it but i have now moved it back 1 place so now pin 1 of the array is connected to 0v insted of 5v.
I now have a new fault it just stays on one frequency. If i switch between high mid and low the frequency changes but if i change channel it just stays on the same frequency. The kc shidt still works. I'm not sure if i have created this fault or if it's because i have moved the resistor array.
When i probe the connecting from the channel selector and the eprom i get 0v at a few of the wires but nothing on the others, Are the channel codes a mixture of 8v and 0v or is it normal for some to show nothing?
There are 2 wires with 8v and 1 with 0v coming from main pcb and channel selector, the other 6 got to the eprom.
Richard
It looks like I steered you wrong there, put the array back where it was, that is what I get from going by memory.
coyote116
First Name: Larry
Post by coyote116 »
Be sure to check electrolitic capacitors in any radio over 15 years old....they dry out and short causing many head aches....have experienced it in the 360FM, President Grant DX, Midland 79-260 ...trust me, it happens with age.
Post by zodiac »
Richard,
Can you give us the voltages at the PLL pins for channels 24, 25 and 26 on the UK band as I've done below, just put a 1 for the pins that are switched on at about 8v.
These are not correct it's just to let you see what I mean.
PLL codes.png (2.67 KiB) Viewed 69613 times
mm3stb
First Name: Richard
Post by mm3stb »
I am hoping to have time to have time to work on the radio over the next few days.
Would yo like these reading before returning the resistor array or after?
Thanks for everyones help on this
move the array back first, I was incorrect in thinking it could have been in the wrong holes.
Post by zodiac »
Yes put it back as it was as Scott said.
What I'm looking for is to see if the codes for channels 25 and 26 are the same, if they are then it could be IC7 that's faulty, the binary adder MC14008B.
coyote116
First Name: Larry
Post by coyote116 »
Did you check your resistor array to see if one or more burned out internally?
mm3stb
First Name: Richard
Post by mm3stb »
Can i just double check that you require the volateges for pins 9 - 17 ? pin 1 being next to the dot then working anti-clockwise
Post by zodiac »
NO, not on the Eprom board the PLL, that's the MC145106p IC5 on the main PCB in the radio and it's Channels 25,26 and 27 on the UK band not 24,25 and 26 as I said.
Channel 40 of high band is channel 26 of the UK band so you will be able to get all the other three bands but nothing above that if theres a fault with IC 7.
I could be wrong as I haven't got a radio here with that board in to do any testing on.
Please do them from Pins 9 to 17 in that order, you are correct and I gave it you in the wrong order in the above post.
mm3stb
First Name: Richard
Post by mm3stb »
Sorry for the delay getting back to you. I have been on decorating duties.
I think you misunderstood me. I was talking about the dot on the PLL. Pin 1 of the PLL being next to the recessed dot.
I have the codes for you
25: O I I O I O I I I
26: O I I O I I O O O
27: O I I O I I O O I
I = +8v
I have also checked the resistor array and all pins read 10k
Post by zodiac »
The codes you have given indicate that things are working as they should right up to the PLL itself and points to the VCO needing slight adjustment as Scott said.
Have you made any adjustment to the VCO ?, even though it had an Eprom in the radio before and shouldn't need adjusting.
mm3stb
First Name: Richard
Post by mm3stb »
Ok so i'll have to give that a try. What was is the best way to remove the wax from the VCO? Wil there be anything else needing adjusted after the VCO?
Thanks for everyones input. Much appreciated!
Richard
I would actually say to check the voltage at TP2, watch it when you go from CH10 through to CH40 on the UK band, and see if the voltage stops changing once you get to the channels which are not working, the voltage you see is used to control the VCO frequency, and comes from the PLL, it can only produce so much voltage, and then it tops out, it may be about 6V or so, I cannot remember the actual range of that radio.
If the voltage stops changing then adjust the VCO so that the highest channel in the radio does not reach the maximum voltage at TP2 (leave it a little headroom), also check the lowest channels, for the opposite, make sure that they are still working OK too, if you adjust the VCO too far it can stop the lower channels from working (the VCO covers a certain range, adjusting it moves the range up or down).
Post by zodiac »
Richard,
Did you find the problem yet ?.
mm3stb
First Name: Richard
Post by mm3stb »
I haven't had a chance to look at the radio again. I have been on decorating duties. Hoping to have a look at the voltages at TP2 over the next couple of days. Will keep you updated.
If i do have to adjust the VCO what is the best method to remove the wax from the core of the VCO?
The easiest way is to just pick it out with a small screwdriver, put it to one side, once adjusted, put it back in a remelt it.
mm3stb
First Name: Richard
Post by mm3stb »
I've just tested checked the voltages at TP2.
Ch23: 7.83v
Ch24: 7.89v
Ch25: 7.96v
Ch26: 7.92v
Ch27: 7.92v
Ch28: 7.91v
Ch29: 7.92v
Ch30: 7.92v
Ch35: 7.93v
Ch40: 7.94v
So i guess i need to adjust the vco?
I've got the wax out. should i be screwing the core in or out?
Yep, you need to adjust it, make sure you use the correct size screwdriver to avoid breaking the core.
Monitor the voltage on CH40 and adjust the VCO until it reads 7V, then recheck on CH1 of the lowest band to make sure you have at least 1V there.
Post by zodiac »
You'll find TP2 just at the back of the PLL's pin 7, it's R126, 27k.
It's looking like that's all that's wrong with it and the other Eprom that was in was a good one maybe.
With a bit of luck you'll have it working again soon Richard.
Anybody on 40 to give us a rig check PLEASE.
mm3stb
First Name: Richard
Post by mm3stb »
The old eprom worked fine for a while. it was in the radio when i got it.
So when adjusting the VCO should i be screwing the core in or out or should i just wing it?
When adjusting it should i just monitor the volrtage at TP2 until it rises or is there a set voltage i should aim for?
You will just have to adjust it and watch the voltage, like I said in my earlier post, aim for about 7V on the highest channel the radio has got, and check that you have at least 1V on the lowest channel the radio has got.
The slug could need to be turned either way, as it depends on where it is set now, it is always a case of turning it to see what happens, you will not need to turn it much, usually only 1 turn is enough, but it depends on how far out it is, what I mean is dont just go and screw the slug all over the place, make small adjustments.
I would say the easiest way for you to see what is happening would be to put the radio on CH20, and watch the voltage, you want it to drop by about 1V, when you have done that go to CH40 and check that you have about 7V, and adjust as required.
mm3stb
First Name: Richard
Post by mm3stb »
so i am aiming to bring the voltage down rather than up? As i am geiing 7.94v on Ch40uk
Thanks
Post by zodiac »
Yes that's right.
If you look at the voltages you have given above there is next to no change between channels 23 and 40 as you have reached it's limit.
The PLL runs at 8v so the VCO cannot operate above that, you should see a small increase in the voltage as you change channels from the lowest channel to the highest channel and as it is it cannot do that, it's too high.
mm3stb
First Name: Richard
Post by mm3stb »
SUCCESS!
I have Ch1 low to Ch40 uk. Adjusting the VCO did the trick
Thank you so much for your help.
Now for the 4k7 VR. It states connect to "wiper of course tune" Where should this be connected to? Also the radio is slightly off-frequency should i put it back on frequency before adjusing the 4.7k VR if so how do i go about that?
mm3stb
First Name: Richard
Post by mm3stb »
Post by zodiac »
Connect a wire from the 4.7k variable resistor to the unused hole for L35 at the front of the board, this leads to the centre of the KC shift. Connect another wire to 0v Grnd back to one of the other pins at the VR and adjust the VR for the UK off set.
Post by zodiac »
Richard,
I forgot to mention that one of the wires from the VR needs to be wired to the same switch as the one you are using to switch to the UK band, it goes on the other pole or other side of the switch.
The switch should be a two pole switch with three pins on each side making it a two pole switch, see your drawing with the Eprom fitting instructions.
As for aligning the radio you'd be better to take it to someone with the proper equipment and experience of working on the radio, the adjusting slugs are very delicate and brake easy.
mm3stb
First Name: Richard
Post by mm3stb »
OK,
I have Wired it up as per follows. L35 - centre pin on switch - top in on switch to middle leg of 4k7 VR - right leg of 4k7 VR soldered to can L15.
When i try to adjust the frequency on ch1 I can only get it to go as high as 27.60049 instead of 27.60125 with VR turned anti-clockwise. When turned fully clockwise i get 27.59307.
I have check that corse tune is in the centre position and KC shift is off
Any ideas where i'm going wrong?
Post by zodiac »
Richard,
From what you've said it would appear to be wired correct.
The coarse fine tune should both be at the 12 o'clock position when making the adjustment to the added 4.7k VR.
You did say that the radio was off frequency and maybe that's the reason why it won't tune in but if you look at the maths you've given there's only 0.00742 of movement from one end to the other, it should have about 4 to 5KC's on the 4.7k VR. So something is not right and even with the radio off frequency it would still move a lot more than it is.
Check the wire you fitted in the empty hole for L35 and follow the track to the left turn the radio over and you should see the screen print above the wire that's in that hole, it has (M) above the wire and COSE below it.
The wire that's in there goes direct to the centre pin of the coarse tune and saves you the trouble of removing the front of the radio to take the control out to fit the wire on.
Also the AM/FM power adjuster VR13 is turned up full, I'd turn it down if it was my radio.
mm3stb
First Name: Richard
Post by mm3stb »
Thanks, will give it a go when i next have the soldering iron out. the radio is just slightly off frequency so i would of thought the trimmer would of compensated for it. Thanks for the advice on VR13. Will turn it down. Everything is the way it was when a got the radio with the exception of the relay board and old Eprom. It came from a tinkerer me thinks.
