Uniden 810e Driver and Final Transistor Replacement
THIS IS UNTESTED i don't have this rig sorry
Required Parts:
2pcs ERF-2030
1pc EN-369DR
1pc EN-369FN
1pc 1000pF ceramic disc capacitor
1pc 33K ohm, 1/2 watt resistor
1pc 470K ohm, 1/2 watt resistor
Heatsink Compound
1 Remove Final
2 Remove Driver
3 Remove L29
4 Remove L32
5 Remove C143
6 Remove C211 NOTE: Is on back of PCB @ finel 470P/UJ
7 Remove C145
8 Remove C202
9 Remove C180
10 Replace both Final and Driver with ERF-2030s. Note: ERF-2030 mounts identically to the Ones you removed
11 Add 33K ohm resistor (1/2 watt) (solder side of PCB) from ERF-2030 gate leg of Final to the end of R170 that is closest to the face of the radio
12 Add 470K ohm resistor (1/2 watt)(solder side of PCB) from ERF-2030 gate leg of Driver to the right leg of VR9 that is closest to the face of the radio
(NOTE: BOTTOM VIEW OF PCB The ERF-2030's Gate is the Right most leg and the Source is the Left most leg)
(Note: insulate the leads of the resistor from the surrounding traces using heat shrink tubing.)
13 Add 1000pF ceramic disc capacitor across C146 (solder side of PCB) NOTE: keep C146 470Pf in place..
14 Install EN-369FN at Final (solder side of PCB). Solder the positive lead (+) to the ERF-2030 gate.
Solder the negative lead (unmarked) to the ERF-2030 source.
15 Install EN-369DR at Driver (solder side of PCB). Solder the positive lead (+) to the ERF-2030 gate.
be sure to check all work!!! and go over your Schematics and PCB Layout.
I hope this helps 617
I makes no warranties or representations as to its accuracy and assumes no liability or
responsibility for any errors or omissions in the Content of this post TRY AT YOUR OWN RISK!!!!
