RCI 2950DX e chip problem!
Posted: Sunday 14th Feb 2010, 6:26
by soundmanjim
Radio Make and Model: RCI2950DX
PCB Number: EPT695014B
Test gear available:
Symptoms: Just bought this radio off Ebay - guy said it was working 24-32. When i switched it on, only 24 and 28. then i found the mod by tapping MAN on the front. All good.
Then halfway through a chat with someone on FM, the radio defaulted back to 24-28 and the MAN button would do absolutely nothing. :shock:
I removed the cover and unplugged the e-chip. turned it on, then back off again, then reconnected the e-chip. Turned it back on - perfect. :D Then during a chat, 'beep' and the thing goes back to ham mode, and the man button wont do anything. Took the lid off again, unplugged and re-plugged the chip - working - but only until i turned the channel change, then it plopped back onto 24.890. :banghead:
I actually put my finger on the tiny pcb whilst turning on the rig and this cures the problem, but as soon as i take my finger off of it, it defaults again. Dry joint?
What is working: The rig is in perfect order, all modes and contriols work, apart from the MAN button to change from Ham to CB mode.
What has been tried: removal and refitting of e chip
Did it suddenly happen ?: yes
Anything else that may be of help?: i am beginning to think that the E chip may be faulty - or an smd is not making proper contact - i dont dare wave my soldering irion at it, ill just make things worse.
Any suggestions? Can anyone tell me where i can buy another e chip?
73's
Jim
Re: RCI 2950DX e chip problem!
Posted: Sunday 14th Feb 2010, 7:39
by zodiac
Have you got a friend that has the same radio that you can borrow the chip from, just to see if that's the problem before you buy one.
Posted: Monday 15th Feb 2010, 17:25
by soundmanjim
Hi Zodiac.
unfortunately no.
As an update however, i seem to have cured it by squeezing the thing as hard as i could between thumb and forefinger. pretty sure its a dry joint now.
where are the e chips available from and how much do they cost roughly?
regards
jim
Posted: Thursday 18th Feb 2010, 11:43
by zodiac
You could try Richard at Truck-King, he may be able to help you.
01636 676 898
Tell him Dave in Oldham gave you his number.
Posted: Monday 8th Mar 2010, 2:40
by angusuk
ok if it works when you press it together just put 2 or 3 tiewraps round it and pack as needed that will probly work for years to come,and you will save some pennys,
