Radio Make and Model:
Test gear available:
Symptoms:
What is working:
What has been tried:
Did it suddenly happen ?:
Very Quite audio, TR396FCC
- First Name: Jerry
73 from the shade of the big mountain, Pike's Peak!
KD0JVP (General)
KD0JVP (General)
- First Name: Jerry
Re: Very Quite audio, TR396FCC
I don't know what happened to my first post so I'll try it again.
I have a TR396FCC and the audio is very quite. If I turn the volume up all the way I get just a tiny bit of white noise. I hooked up 2 radios on my work bench and transmitted on the 396 then switched the antenna and got a reply on the second radio so I know the 396 is transmitting.
I have loud talk-back and PA. I've replaced IC8 and IC1 and four transistors trying to locate the problem. I've tested all the transistors and diodes (I think). I noticed today that when I turn the RF gain control all the way up or down it makes no difference. I did some more checking with my equipment which is a Huntron tracker, an o-scope, a signal generator and so forth and found that I had signal at TP3 but not at TP2. I than pulled IC2 out and checked it with the tracker. There is no connection internally between pins #6, 9 and 10. I have a feeling this might be the problem but I'm just not sure. Plus I don't have any of these around or in town I can get too.
If anyone out there can help me out I'd really appreciate it. I've been going over this radio for weeks now (I'm new to radio repair ) and I've had nothing but headaches from it. Help!
KD0JVP (General)
KD0JVP (General)
mate , i've had problems like this on an 858 chassis. Check the electrolitics ( caps ) feeding the input of the audio chip. I had one problem where the cap was open curcuit.
Infact , just replace the caps around the audio amp.
Hope it works for you.
- First Name: Jerry
Thanks for thew reply uncle ray but I sent it to a shop. I just couldn't wait any longer. If I can remember I'll post up what the problem was when I get the answer from the shop.
KD0JVP (General)
KD0JVP (General)
