nato 2000
Posted: Sunday 22nd Aug 2010, 11:38
by buzzby
hi can anyone tell me how to change the n/b switch to set the rig up for zeros exp 27.560 it would be a lot better that using the kc jump switch regards philip :)
Re: nato 2000
Posted: Wednesday 1st Sep 2010, 8:28
by zodiac
If you connect a wire from the centre of the KC shift and put it to a switch, then find a variable resistor of the same value as the KC shift control, put another wire from the switch to the variable resistor and the other side of the variable to 0 v (GND).
Now adjust the variable resistor for the zero.
If you want to use the NB switch, just hard wire and insulate the wires that are on the switch then you can use it for zero switching.
Re: nato 2000
Posted: Wednesday 1st Sep 2010, 12:03
by zodiac
This should help you .
