Superstar 3900el low FM tx audio
Radio Make and Model: superstar 3900 el
Test gear available:multimeter
Symptoms:very lowTX fm audio
What is working:RX audio
What has been tried:Nothing
Did it suddenly happen ?progressively:
Anything else that may be of help?: when the radio is just turned on the audio is perfect but as the radio is on for a period of time the audio goes very low to almost zero
Re: Superstar 3900el low FM tx audio
John,
You need to fit a small heatsink to the audio chip after moving it away from the chassis as it is when standard.
You will also have to re-fit the large electrolytic capacitor by extending it's pins so it can be bent out of the way of the new heatsink.
This work should have been done by the seller before you bought it.
Happy Christmas to all.
Thanks Dave
Merry Christmas
Dave can you please give me the location of the audio chip on the radio
Many Thanks John
Merry Christmas
Many Thanks John
The drawing should help you find it.
- Audio IC.png (10.55 KiB) Viewed 19455 times
Cheers Dave
Thank you for your help
John
John
Hi Dave
Me again the audio chip has a small heatsink behind it
i have replaced the audio chip with a new one but the problem is still there the radio is 100% when first turned on but about an hour later the audio starts to go is there any other component what will cause this also i have noticed the outside of the mic socket gets hot be very gratefull for any help
regards John
regards John
John,
I misread your problem, you are asking about the TX audio and I've given you info on the RX audio for radios with the TDA2003 audio chip, sorry.
no worries Dave
shall we start again then lol
hi again
just wondering if anyone has got a soloution to this problem
Thanks for the post...
Get fast success in Pass4sure 300-135 exam questions by using our latest exam LPI .We also offer up-to-date University of Pennsylvania and answers for you.
