President Jackson II (FIXED)
Posted: Friday 4th Feb 2011, 0:27
Hi there,
Grettings from Portugal
Radio Make and Model: President Jackson II (new model)
PCB Number: PB-351AB 1/4
PLL Number: Z0740B6
Test gear available: Autoranging multimeter and frequency cunter (no oscilloscope)
Symptoms: No output needlle doesn´t moves
What is working: Everithing else work´s
What has been tried: check for shorts on the non SMD transistors
Did it suddenly happen ?: Not sure
Anything else that may be of help?: This radio arrived with the coil attached to the negative pin on the plug (on the rear) broken/opened and the PCB around it all black
I repair TV´s and a friend asked for help on this radio.
We have tested it in my shop, and it only receives, when we press the PLL nothing happens, the needle doesnt moves (no output)
I have searched on-line for the esquematic but didnt found it.
Any help would be appreciated
(SORRY MY BAD ENGLISH)
Best regards
Nezocas
PLL Number: Z0740B6
Best regards
Nezocas
