Radio Make and Model: cobra 29 ltd bc
Test gear available: not much
Symptoms: will not turn on
What has been tried: replaced d23
cobra 29 dead
Re: cobra 29 dead
i would really appreciate it thanks guys
Re: cobra 29 dead
Use a volt meter and check to see if your getting 13.8 volts at the on/off switch.
Robert
Robert
Re: cobra 29 dead
Does the meter light up?
Does the channel display light up?
Has the inline fuse blown in its power cord?
Have you checked for 13V at the on/off switch to confirm that power is getting to the radio itself ?
Have you made sure it is not set to PA mode?
You should be getting 5V at D19 with the radio turned on if power is getting that far into the radio.
Re: cobra 29 dead
radio is on and not in pa mode i have not poped the fuse and what wires at the on/off swich
Re: cobra 29 dead
Can you please answer EACH of the questions I asked, I need to know the answers to all of them in order to be able to narrow down where the fault could be.
On the back of the vol/on/off control there are two connections, usually a red wire and orange wire, you should have 13V on BOTH wires when the radio is turned on.
Re: cobra 29 dead
oh sorry
Does the meter light up? no
Does the channel display light up? no
Has the inline fuse blown in its power cord? no
Have you checked for 13V at the on/off switch to confirm that power is getting to the radio itself ?not yet
Have you made sure it is not set to PA mode? yes
have not checked sorry about that was in school
Re: cobra 29 dead
ant thoughts guys
