cobra 146 GTL mod ?
cobra 146 GTL mod ?
can the cobra 146 gtl be moded for extra channels
Re: cobra 146 GTL mod ?
Yes, but it's not a mod for a newbie. Either buy an easier to mod radio, or take it to someone who knows what they are doing.
It involves rewiring the clarifier and either changing the PLL or changing the downmix tripler into oscillator(s).
Google "upd2824" and you should get all the info you need.
Take a look on transmission1 in the Uk at Clint's post, "converting my AR144 to 555"
http://www.transmission1.co.uk/forum/vi ... 35&t=16811
They are the same board and the information is very good with phots.
This might let you hit 555, but your clarifier range will be lousy and you'll also have problems centring LSB and USB at the same position of the clarifier.
A PLL swap with EPROM addressing (i.e. a MC145106 PLL with a 27C64 EPROM) will solve these issues and give unbroken 5K steps, but like I said before, neither option is practical for those "newbies" without both experience and the right tools for the job.
- First Name: Samuel
thanks for good post +1
I recognize I oft use academic editing, because it is important assistance for me. I cannot avoid many difficult mistakes concerning Grammar and style.
- perrym1962
If you can find one, a galaxy A kit will work in them. Also a expo 100 "N" kit will work in it. But the problem is finding them.
Depends on your definition of "work"a galaxy A kit will work in them. Also a expo 100 "N" kit will work
The '2824 PLL clarifies and does the SSB offsets by varying the 10.240 frequency slightly.
This is halved and then tripled to 15.360 and mixed with the VCO.
The offsets are preserved by this math stuff and the radio operates at the correct frequency for AM, USB, and LSB.
These "expansion kits" inject a new signal around 15 to 17 Mhz to trick the PLL into going to places it wasn't intended to go.
The problem is they have a fixed offset that can only be set for one of the 3 modes, and most don't have a clarifier offset.
This reduces the clarifier range by about 75% and means it's impossible to center the clarifier at 12'o'clock on all the modes.
Like I said before, these kits might let you hit 555, but your clarifier range will be lousy and you'll also have problems centering LSB and USB at the same position of the clarifier.
Of course, you can add 2 more offsets and a clarifier circuit to the kit, but it's not worth the trouble.
Better to change the PLL if you have the patience / knowledge, or buy an "export" radio if you don't.
Sue
- perrym1962
All I know is I put a galaxy a kit in a 146 that I had. It yielded 40 low channels and 40 upper channels. The instructions came with it and was fairly simple.. I did not try ssb, but on the am side worked perfectly..
- perrym1962
I did it to suit me. I don't really care if anyone else "approves"...
