Freq. counter
Posted: Saturday 25th Jun 2011, 6:28
Radio Make and Model: cobra 2000gtl
PCB Number: 497
PLL Number: mb8719
Test gear available: Dvm/anolog m
Symptoms: freq. counter
What is working: entire radio
What has been tried: cobra bulletin 1232
Did it suddenly happen ?: next day
Anything else that may be of help?: hello men,The problem started with dimming of the channel selector and meter lights with the radio turned off, so i changed fets 501-502 in the freq. counter module and everything worked fine,the next day I turned on the radio and the counter read 92.2000 so I changed all the elect. caps replaced Diode 528 with a 1watt zener replaced the following Tr519,Tr 522,Scr501,and it still reads the same.I took another module out of another cobra 2000 I have and tried it and everything was working fine,so theres something in the old module thats bad? The radio works fine,I can change channels and all is good with the original module except the counter continues to read 92.2000 please help..Thank you
PCB Number: 497
PLL Number: mb8719
