Radio Make and Model: galaxy 959
PCB Number: EPT069610Z
PLL Number: RCI8719-99
Test gear available: SCOPE, SIGNAL GEN., DVM
Symptoms: will not key or transmit on AM although will on LSB and USB
What is working: Everything seems to be working on radio except for the AM issue
What has been tried: realigning and tuning
Did it suddenly happen ?: no
Anything else that may been e ofR276 has b help?: I did remove a echo board that was istalled by someone else. I do see that R276 has been removed.
