How To Tune Tube Amp To Radio
I Have A D/A Phantom 1000, 12 Tube Amp The Tubes Are 6lq6. My Radio Dead Keys 3.5 Watts Swings 15.How Should This Amp Be Tuned And What Kind Of Wattage Is Best For Dx Use.
- rubbandman
D&A tuning
You need to drive that amp w/ 10 watts no more than 20 , Start w/ Driver tune and key the amp and adjust to max out put then wait a few ( Double the key down time) then key and tune "Load & "Tune" knobs you should W/Good tubes get a 1000 watts then make sure you check your SWR's and make sure your not back Modjing , if you want i've got the Manual for it I'll E-mail it to you........................... I run a D&A Mavrick I Dig it !!
Max!
Max!
- bullfrog13x4
if you go to cbtricks website and go to the amp section there is a complete owners manual for the phantom triple stage wich tunes the same the main difference is the triple stage is 4 driving 6 and yours is 4 driving 8 so if you follow the instructions in the manual you will tune it properly you will see more peak than the manual refers to becouse of your extra 2 tubes.
hope this helps
happy 73's
hope this helps
happy 73's
maverick 250
I need a copy of the maverick 250 amp manual, cannot find it anywhere. Does anyone know where I might find one?
