Those that have one of these will know they're based on the Mk1 Cobra 148 GTL-DX, and also they have BLOODY AWFUL FM deviation! And that brings me cunningly to my problem; how do I change the bloody awful FM transmit audio? I've already put an Astatic "Teardrop" on it, and even with the tone as high as it'll go it's not THAT great.
Also, how do I find the roger beep circuit, cos I wanna reconnect it. Anyone got a schematic for one of these?
Thanks in advance.
Superstar 360 FM question
- Ron Fouler
I'm NOT Satan: It's 2 six's and a 9!
26-LB-6
26-LB-6
Ron,
The Superstar you have is it the MK1 or the MK2, the reason i ask is that both of them are the same as the MK1 and MK2 Cobra 148GTL DX but the MK1 sounds as you said on FM if you turn the deviation VR up too far, it makes them sound like a Cybernet Multimode 2 for the same reason overdeviation. The MK2 sounds much better on FM you can turn the deviation up on them without any problems as long as you don't go too high.
As for the schematic, there will be one available very soon on a CD for both the MK1 and 2 that's being re-drawn at the moment with loads of extra information on it to make it easier to follow for people like me. I can't wait to get my hands on one when it's finished, I've seen part of it and it's nothing like you've ever seen before plus it's being done in England so there won't be a problem with the postage.
Ron,
Forgot to mention, the beep transistor on the MK2 is TR33, not sure if it's the same for the MK1 but you can check it out to see if it's got one of the pins lifted as that will stop it working. You'll find it at the front right hand side about 1/2 inch in and 1 inches from the front edge on the MK1, the MK2 it's 1/2 inch in and 1/4 inch from the front.
- Ron Fouler
- Ron Fouler
- Ron Fouler
