Dragon TRC485 VCO Moddfication
Posted: Wednesday 27th Sep 2006, 12:55
Hi.
I own a Dragon TRC485.
I already did the trick to get 400 channels using this:
http://www.radiomods.co.nz/trc485mod.html
But "To transmit / receive on all of the 400 channels it is necessary to adjust the VCO."
I've adjusted the VCO tuning the resonance coil but in that way i can only move the window to an upper or lower frequency, but i can get the same excursion (1,7Mhz, e.g. from 26.705 to 28.475).
I would like to get at least 2,5 MHz of covering. So i modified the VCO:
I putted a second varicap with a different capacitance curve in order to use it to work in other frequencies. I turn between original varicap and added varicap using an electronic switch. I build the mod it in a very small area near to the original varicap and isolating everything from annoy RF interference from other radio parts. Then I adjusted the trimmer to avoid varicap's bands superposition.
I tested and it was OK, PLL working OK, I've got an 2,6 MHz covering BUT transmission is very noisy due to the poor quality carrier that the VCO is producing after my modification I think. I even add 0,1uF capacitors in parallel to the switching diodes but i only got a band reduction.
Someone can please suggest me another way to do this? Maybe adding a brand new VCO to the radio?
Please help me!
THANKS IN ADVANCE!!!
Please help me!
