* Hook up radio to power and turn on for a minimum of 10 seconds.
* Turn off radio and disconnect from all power sources.
* Remove Bottom cabinet cover.
* Locate Diode D2 on the vertical Front Panel PCB (see image below), this
is the only Non-Surface Mount component found in this area.
*Clip or remove (unsolder) Diode D2.
* Reset the radio CPU by temporarily shorting the two front panel circuit
board pads (see below) located near & just right of Black Potentiometer.
* Hook the radio back up to power and turn on the radio.
* Press the FUNC button, then press and hold the CALL button for approx.
3 seconds. The frequency and band indicator ( A-J) will appear on LCD.
* Tap the CALL button to select bands A through J. FCC CB frequencies
are on band E.
* To switch between channel and frequency display, press the FUNC button
and then press the CALL button.
* When turned off and on again, the radio will always default to original
10 meter settings.
* To automatically return to last used frequency and mode, simply tap #4
button or press the FUNC button and then press and hold the CALL button
for approx. 3 seconds.
This version of the mod was sent to me by Bookworm, thank you.
I have an addition to your magnum 257, Roadmaster Titan II, etc. mods page.
I recently aquired a Titan II and all I had to do was find the four pins at the (conv1) location on the board and jump them (1&2,3&4).
thanks..bookworm
A quick way to change bands, sent to me by Cris
For the Titan II, Black Hawk, AE845, Magnum 257 & 357
Instead of using the func switch and the holding the call button for 3 seconds, program into memory a channel in 11 meters or use LCR. quick and easy.
This version of the mod was sent to me by Andy, thank you.
In reference to the Magnum 257 mod, I just got a new one and there's been a slight change. There is now a "reset board" inside the radio that contains a reset button so you don't have to short out the board to reset. Also, the diode that you clip to get extra frequencies is no longer there. There is now a jumper on the reset board. You move it from CN1 to CN3 and it opens the frequencies, no cutting/soldering required!
The reset button and jumper are the only differences in the mod, everything else remains the same.
Possible conversion info, not sure it is for this radio, but it looks like it may be !
1 - Audio
2 - Receive
3 - Transmit
4 - Ground = Channel Down, 22K Ohm
to Pin 3 = Channel UP (was originally listed as 2.2K, a visitor
told me it was wrong)
5 - Ground and Switch common
6 - 13.8 Volts. SEE CAUTION BELOW
CAUTION: Shorting-out Pin #6 can cause damage to radio! If you decide
to install a new mic, we strongly suggest you remove pin #6 from the
mic plug to avoid any possibility of a short!
RV-1 - S-Meter Signal Strength
RV-4 - AMC, AM Modulation
RV-8 - RF Output Meter
RV-9 - ALC, SSB Modulation and Peak
Power.
RV-14 - FM Carrier Power
RV-16 - AM Carrier
This counter shows the number of hits since the 4th June 2002
Go Back To The Modifications Page
