This mod was sent to me by Doug, thank you
1. Remove the top cover.
2. Look at the back of the faceplate circuit board and there is a jumper connector.
3. Move this jumper off of the pins that it is on now and put them on the other 2 pins.
4. Replace the top cover.
1-remove top cover
Once the channel modification has been done press (you may need to hold it down) channel 9-19 button and then turn on the radio.
After this mod use the number 1 button to select different bands of 40 channels.
Copyright © RadioMods 1997-2016
