This page describes how to add more channels to the Danita 1608
I found this mod at http://www.c-and-l.freeserve.co.uk/
this is a site that is well worth a visit if you want to buy CB related parts
in the UK.
In expanded mode the frequency coverage is:
A: 26.165 - 26.555
B: 26.565 - 26.955
C: 26.965 - 27.405
D: 27.415 - 27.805
E: 27.815 - 28.205
Note that there are no ïAÍ channel gaps or ch 23/25 swap around except for band C Æ which is the normal CEPT band. There is also no band indication.
The radio works as normal when switched on.
To activate the expansion, switch on while pressing the channel button
Note the channel 9 function is no longer active
If no TX lock at one end of range, remove cover of PLL screening box and adjust coil till lock is achieved at both ends of range.
If RX lock cannot be obtained at both ends of range adjust T3.
If still not possible replace C15 (56p) with 33 or 39p.
