Ham Intl. tuning prob
yazzo
First Name: yazz
Post by yazzo »
Radio Make and Model: Ham International Concorde II
PCB Number: PTBM121
Test gear available: Freq counter
Symptoms: Mid band cannot be tuned correctly, CT2 will go 20.327-20.328 MHz
What is working: Lo and Hi band can be tuned normally
What has been tried: Changed Mid band crystal to Lo band slot and did the same thing there
Did it suddenly happen ?: Worked fine 2 months ago, has been powered off and now it doesn't
zodiac
Re: Ham Intl. tuning prob
Post by zodiac »
It sounds like the Mid band crystal has had it's day and needs replacing, what frequency is on it as I might have one.
yazzo
First Name: yazz
Post by yazzo »
20.330 MHz, grrreat if you have one :D
zodiac
Post by zodiac »
How many do you need. :lol:
yazzo
First Name: yazz
Post by yazzo »
I'll be happy with one! You will receive pm shortly.
zodiac
Post by zodiac »
What type is it, is it plug in or soldered in.
yazzo
First Name: yazz
Post by yazzo »
Plug in. There are slots for xtals in the board.
zodiac
Post by zodiac »
I've posted you one of each, with a bit of luck that should sort your problem out.
yazzo
First Name: yazz
Post by yazzo »
Thanks!! =D>
yazzo
First Name: yazz
Post by yazzo »
Got it today, thanks a million for fast mailing and bringing HAMmer back to business!!
zodiac
Post by zodiac »
Your welcome and if you ever need a S.Hi crystal I've got loads of them.
Dave. :D
