I have a problem with my PJ
Model - President Jackson (A-F band version black faced)
PCB - PB-042AE
PLL - Don't know (Kinda new to this stuff) I think its MC145106 maybe
Radio is stuck on transmit.
It has been modified with following mods: hxxp://www.radiomods.co.nz/presidentjacksonmods.html
It also has a modification that reduces AUX-output lvl so that it is better suited for packet radio. (just ceramic cap and 2 resistors)
Tryed so far:
I removed the modifications, still transmitting.
I removed the W26 (yellow wire) going into the small PCB infront of the radio, it stopped transmitting. Schema says its TX-FREQ, what confuses me is that its attached with roger beep.
Some other stuff to go with:
When I go to low band A and set channel to 40 and switch between roger on / off following happends -->
ON - transmit and receive leds flicker and signal meter jumps up and down like crazy
OFF - both leds are lit and receive flickers a bit. Signal meter steady at max (this also happends on all other bands).
I'm pretty much clueless about that can cause this, but from symptoms I assume either transistor or capacitor failures. Help a bit please, I'de hate to throw this thing into the garbage bin
Person who has modified this CB refuses to take blame and doesn't want to "fix" it, and he said it should last a life time with these mods.
PS. I can provide photos of the mods if needed.
