Belcom LS-102
Bignasty
Belcom LS-102
Post by Bignasty »
Does anyone no where i can get a manual and tech notes for a Belcom LS-102-id really appeciate it!Every time you switch the radio of and switch back on it reverts to 000 on the freq counter,is this a battery problem?and if so what type and where can i get a replacement,Does anyone no what the radio was based on as it has 7.8 filters that ressemble my old yaesu?
Regards All
Mike
You only live once!!
Re: Belcom LS-102
I have put a copy of the owners manual on CBTricks which may help. I am re-drawing circuit diagram but it will not be completed for a few more months
Blow is the URL
www.cbtricks.com/radios/belcom/ls102l/index.htm
Bignasty
Belcom LS102L
Post by Bignasty »
Thanks for that Rick,do you no anything about the feq reverting back to zero when the power supply has been switched of?it stays as it was if switched of from the on/off volume switch but as soon as the mains has been switched of the display goes back to zero?
Regards
Mike
Re: Belcom LS-102
There was a mod for this problem, which was done with a NiCad battery, two diodes and resistor, but we are talk about a radio, which I have not seen for over 20 years. I will see if I can find my old notes but I would not hold out much luck.
