talkback rely
Posted: Thursday 15th May 2008, 6:40
by bigboy250
any body have any on how to put a talkback rely in and take out factory one? on a gen. lee
talkback rely
Posted: Monday 15th Dec 2008, 3:58
by Dodgem250
you want to do what now? Take out a talk back relay? Email me with some details, I don't quite understand the issue.
Dodgem250@somd.net
talkback rely
Posted: Tuesday 16th Dec 2008, 6:07
by timrim
All you will need to do is simply remove all wires, near the external speaker jack, you will find a jumper that this relay went to, you will need to install the PCB jumper back in that spot. The relay is glued down, so gently pry up from board. As for putting it back in, I don't recommend using the relay method, I just don't like it. If you need to have a decent talkback, and adjustable, I always use the Magnum Universal Talkback board, they are awesome!
