Needing Schematic: Rebel TX500 (Mongoose 450) CB radio
wcsd106
First Name: Josh
Post by wcsd106 »
Radio Make and Model: Rebel TX500 (Silver faced clone of Mongoose 450)
PCB Number: jpmxx0222-a
PLL Number: MC145106
Test gear available: Most test gear available (Currently without oscilloscope as I sold mine a few years ago when I considered getting out of this business and haven't purchased a replacement yet.)
Symptoms: Radio shows no transmit wattage. Radio can be heard slightly on a nearby radio, but no output power is observed. Checking transistor voltages against an identical working model, Q18 (RF Amp) does not jump to +12v on tx. Stays at 9v regardless of key condition. No voltage chart or schematic available to aid in troubleshooting this unit.
What is working: Receiver working 100%, audio section seems to be working.
What has been tried: Final & driver have been replaced with known working components (acted like final at beginning)
Did it suddenly happen ?: Radio was purchased in non-working condition from Ebay
Anything else that may be of help?: have identical radio (Mongoose 450) in 100% working condition. I have been using it as a 'control' radio to observe voltages for reference. Also, according to an info sheet I read on the Mongoose, when troubleshooting transmitter problems it said to check for a faulty D15. I cannot locate Diode D15 on this chassis.
If anyone has a service manual or schematic on this radio, or could point me in the right direction to obtain one, it would be greatly appreciated.
Thanks.
Kosmic
Re: Needing Schematic: Rebel TX500 (Mongoose 450) CB radio
Post by Kosmic »
Josh they are very sdimilar to a Tristar 240 as far a circut. Hopefully this helps.
