need help from the 148 gtl experts.???
Posted: Sunday 4th Jul 2010, 12:03
by 1iwilly
Radio Make and Model: cobra 148 gtl
PCB Number:philly made 1993
PLL Number:rci 8719
i got this radio a while ago it has low modulation when all the limiter are intact radio dead keys 2watts swings to 3 1/2 if i cut r131 then it swings to 8 watts on a bird
i try the 1k resistor to middle leg of tr24 i try tr26 too no luck i've change tr41 upgrade one tr 42. also ssb is fine no modulation problem only on am
i even change tr 23,tr24,tr24,tr26 no luck i also change r124,r126 to 4.7k and r131 to 4.7k no luck. thanks :banghead: :banghead: :banghead:
Re: need help from the 148 gtl experts.???
Posted: Sunday 4th Jul 2010, 18:43
by lbcomms
You'll get more chance of a reply if:
1) You don't try to put lots of sentences into one. Punctuation, paragraphs, and correct capitalisation make things much easier to read for someone to help you.
2) Do a bit of basic research first. Try Google.
3) Learn a bit about what you are trying to archive. How are you measuring your "low modulation"? Have a look athttp://www.radiomods.co.nz/forum/viewto ... f=1&t=2914 for more info on this subject.
Good luck with your problem.
Sue
Posted: Sunday 4th Jul 2010, 23:56
by 1iwilly
sorry about that.
i was trying to explain all the stuff that was already done to the radio.
so i don't get hit with change this change that.
i'm using a bird meter. i also have the sams photofacts.
Posted: Monday 5th Jul 2010, 0:10
by 1iwilly
i forgot to add,i also have a multimeter,and a 6 amp power supply.
Posted: Monday 5th Jul 2010, 0:18
Check the voltage drop across R111 (tell us the voltage on both sides of it, in TX and RX), I have come across issues on this and similar chassis where a capacitor is loading down the DC supply causing a large voltage drop across that resistor, it sounds similar.
Posted: Monday 5th Jul 2010, 1:51
by 1iwilly
The Defpom wrote:Check the voltage drop across R111 (tell us the voltage on both sides of it, in TX and RX), I have come across issues on this and similar chassis where a capacitor is loading down the DC supply causing a large voltage drop across that resistor, it sounds similar.
OK on one end of the resistor, i have 7.94 volts, the other end reads 8.34 volts this is on RX. on TX they don't change.???
Posted: Monday 5th Jul 2010, 1:57
That sounds fine at that point.
Posted: Monday 5th Jul 2010, 2:03
by 1iwilly
thanks to all that replied.
i think i found the problem when i was doing the 1k resistor mod. i was doing it to the middle leg of TR26.
after re checking it suppose to be TR24, now i have full swing in am.
