Problems With Receive Audio On MK2 Cobra 148 GTL-DX
Posted: Saturday 30th Apr 2011, 8:49
Radio Make and Model: Cobra 148 GTL-DX (MK2)
PCB Number: PB010AB
PLL Number: MC145106P
Test gear available: Digital Multimeter
Symptoms: Receive audio is quiet and distorted on all modes. There also seems to be quite a lot of noise present.
What is working: TX fine, RX signal fine, all bands work fine.
What has been tried: Replaced 7222 audio ic, both 1000uf caps.
Did it suddenly happen ?: Radio was bought off eBay. Had been wired reverse polarity. RP diode had blown. This has now been replaced.
Anything else that may be of help?: With the volume control set to full the receive audio is still quiet, but the incoming audio seems a little clearer than on a lower setting.
PCB Number: PB010AB
