This mod was sent to me by Roy E. (Weasel)
I have a new General Stonewall Jackson Base Radio ( 10 Meter/CB ).
The channel mod is to remove the bottom plate on the radio.
With the front of the radio facing you and the radio bottom off, you will see four small resistors near the right front side.
These resistors stop the band switch from working.
Simply remove the resistors that are all tied together in a clump.
Take them out, cut or unsolder.
That is it, the Band switch will now cover the bands A thru F with channels just like the Galaxy 2517 or Galaxy Saturn - 25.615 thru 28.305
This counter shows the number of hits since the 6th February 2003
Go Back To The Modifications Page
