Uniden PC78LTW cooked
Posted: Thursday 5th Jun 2008, 14:02
by rac29fan
Well yes I did, I hooked my PC78LTW up to a trickle charger thinking I could power it up that way. Your right I fried it. Any idea what diode I need to look at
Posted: Thursday 5th Jun 2008, 14:43
by timrim
The polarity diode is almost certainly toast. You can find it by following the radios power wires down to the board. It will be a black diode, more than likely, it may be cracked down the middle. If the diode is shorted, then the rest of your radio is probably ok.
Trickle chargers are very unpure and unfiltered DC, they have an AC component to them which is why it fried your radio.
Posted: Thursday 5th Jun 2008, 14:57
by rac29fan
Ok thanks. I'll try that in the next couple of days and let you know.
Posted: Sunday 8th Jun 2008, 18:18
by frogman296
d17...it is in the rear by the transformer...1n4004 is the diode number
Posted: Monday 9th Jun 2008, 10:52
by rac29fan
Ok it was D23. I replaced it and it's working great. 2@ $0.99 at radio shack. Thanks for the help.
Another thing I'm trying to learn is positive side and neg. side. I have a Cobra 25 that I tinker with trying to learn. I lifted the foil trying to add a swing kit. How do I identify where to hook up a jumper wire.
Posted: Monday 9th Jun 2008, 13:09
by frogman296
rac29fan wrote:Ok it was D23. I replaced it and it's working great. 2@ $0.99 at radio shack. Thanks for the help.
my d was for a cobra 29, my bad...you mean you want to fix the trace??
Posted: Monday 9th Jun 2008, 14:58
by rac29fan
I don't know what you call it. (Mabey a trace.) I removed a jumper and damaged the green foil in that 1 spot. I understand I need to soulder a jumper to another point. How do I identify what point that will be?
Posted: Monday 9th Jun 2008, 15:47
by frogman296
are you wanting to still install the swing kit??
if you are just gonna install the jumper back in..solder it in the same area of the foil(wheres its lifted) then to the other hole...you can do this on the foil side of the board
