hey all iam new to the site have a few questions first does anyone know any mods for the 95t2,second is there a echo board with external controls that i can put on this radio already have holes drilled for noise toys so dont mind having more for echo control,and last 2 guys i work with have the magnum radios and i love the way there meter is lit up blue and changes to red when keyed up can i do that with mine just by changing the bulb?
thanks in advance, mike
galaxy 95t2
galaxy 95t2
hi there,well first of all what kinda mods do you want to do to your radio.there are many mods that can be done to this radio.as far a the echo board,you can get one from coppers electronics or h and y electronics or sometimes you can get a good deal on one on ebay.same thing for the blue led bulbs you can get them at coppers,h and y. when you get your echo board.let me know and ill walk you through the installation of it.not too much trouble to install.you also could probably go to cbtricks.com they should be some mods there.are on dxzone.com and go to the galaxy section.......check there for mods.........ramblingman
