I have a uniden grant that quit working on lower ssb and I need L22 as that was the part I found fault. I robbed one out of another chassis and it works but it was a older and different numbered board and cannot get the frequency low enough so it need the correct part if I can find it.
pll 8719
208AD on the board
ift # LA 051 96449
Thanks Kelly
A work around would be to cut the trace leading to L22 and install another small inductor in series with it, you would need to experiment to find the right value, but it will probably be between 1uH and 10uH, this should lower the frequency some more.
