BELCOM LS-102
BELCOM LS-102
Have just picked up an old Belcom LS-102-dont want to sound thick but how do you alter from USB to LSB,their is no selector?has CW FM SSB AM on mode switch then the switchs to the side of that are 1K-100khz for freq speed then FM/hi-low then next switch is send-rec?can anyone enlighten me?the last belcom i had had a USB/LSB selector it was the 102L,its had the 26-30 conversion but someone told me a while back that they can go from 25-30 is this right?PLEASE HELP -REGARDS MIKE
You only live once!!
Re: Belcom LS-102
The LS102 only has USB has it was made for 10 meters where USB was only sideband mode used up 1994, but most hams still use USB on 10 meters today.
The clue is in the model number LS102L.
BELCOM LS-102
Cheers Rick-i certainly would not have thought about it like that!you learn something new every day!!
Cheers Mike
Cheers Mike
