cobra 29 wx st color coding prob.
sqwiggie22
Post by sqwiggie22 »
Radio Make and Model: Cobra 29 wx st color coding problem.
PCB Number: kepc-258
Test gear available: volt meter soldering tools basic hand tools
Symptoms: I was replacing the swr meter the other night when I was just ready to put things back together I noticed the 4 wires for the mic conector came loose. Someone else's poor soldering job. What I need to find out is what color wires go to what number pin. I have a white/yellow/red/blue wire. I am new to this forum and and help is much appreciated.
What is working: Everything but the wire issue
What has been tried:
Did it suddenly happen ?: y
222
Post by 222 »
the way you listed the colors should be the correct order for pins 1,2,3,4 - w,y,r,b.
looking at it from the inside, w/radio upside down, should be 1=top rt, 2=bot rt, 3=bot lt, 4=top lt. hope that helps.
sqwiggie22
Thanks for the info I will give it a try and let you know if that works.
sqwiggie22
Thanks 222 that is the right order. Your a lifesaver I was about to go nuts.
222
Post by 222 »
my pleasure. glad it went so simple.
